Mr. Tap-Dance is a fitting name. Why would he promote the use of FORCEBIOS when that's for a specific purpose.
- CrazyTeeka
- Lurker
I've just joined the GRC forum. Let's see how long before Steve gives me the boot.
- CrazyTeeka
- Lurker
I'll do it for you. I'll probably get the boot soon, anyway.Joep wrote: ↑Thu Nov 16, 2023 1:02 pmYeah, his answer is totally unsatisfactory and I'm trying rubbing his nose in. Saying SMART is nonsense while at the same time: https://www.grc.com/sr/smart.htm .. You can not have it both ways.
Here is a response from Serge:
Serge@DeepSpar wrote:We’ve noticed cases like this several years ago, i.e. drives which would read 1 of 8 logical sectors from a single physical sector. We thought it might be a bug with our tools, so we spent some time testing this, concluded that this is real drive behavior sometimes, and dropped the subject. It’s a bit hard to remember at this point, but I seem to recall that this 1 logical sector that comes back as successful isn’t actually a real read, i.e. it’s garbage data that’s coming back due to some firmware bug of the drive. You guys can check this out, i.e. read that suspicious good sector and check if hex values seem valid.
A key point of larger sector sizes is to combine the ECC together because less space can be spent on ECC that way, so it’s extremely unlikely that any drive is able to successfully correct only 1 logical sector from a physical sector, it should be all or nothing. IIRC drive firmware doesn’t even have a concept of logical sectors internally, there is just a conversion that takes place at the end.
- CrazyTeeka
- Lurker
It makes sense that it's a firmware bug. I'll do some more testing.lcoughey wrote: ↑Thu Nov 16, 2023 6:30 pm Here is a response from Serge:Serge@DeepSpar wrote:We’ve noticed cases like this several years ago, i.e. drives which would read 1 of 8 logical sectors from a single physical sector. We thought it might be a bug with our tools, so we spent some time testing this, concluded that this is real drive behavior sometimes, and dropped the subject. It’s a bit hard to remember at this point, but I seem to recall that this 1 logical sector that comes back as successful isn’t actually a real read, i.e. it’s garbage data that’s coming back due to some firmware bug of the drive. You guys can check this out, i.e. read that suspicious good sector and check if hex values seem valid.
It didn't take long. He just called me an ignorant Internet troll.
- CrazyTeeka
- Lurker
Hmm. New batch of drives arrived from eBay seller. One of them, a Quantum Fireball (IDE) has a burnt chip. Wonder how that happened?
- CrazyTeeka
- Lurker
