Home Articles Articles New Year Resolutions
New Year Resolutions E-mail
With the ringing in of the New Year, it might be the perfect time to add a few technology based resolutions to your list.
Backup Routine: With the increased dependency of digital documents, it is wise to implement a solid backup routine that includes regular testing to ensure that your is data actually being backed up. If you don't have a backup routine setup, contact your computer technician and talk to them about helping you implement a routine that works with your schedule and needs. If you don't have a technician or are concerned about the current routine you have, contact Recovery Force for a referral to one of our Authorized Service Partners.
Hardware Diagnostic: Just as you would check the oil or the air pressure in your tires on your car, you should test your computer's hardware from time to time. As most users won't have the necessary programs to test all the computer's hardware, we suggest you have your technician test your hardware once a year. Things that should be tested include the hard drive, RAM, CPU, CD/DVD Drives, Floppy Drive, Power Supply and the System Board.
Anti-Virus: It is a good time to check to verify that your Anti-Virus software is running and up-to-date. You may want to get your technician to scan your drive for viruses and spyware that might have slipped through over the past year. We strongly recommend that you verify that your data is backed up prior to this process.
Security:
This is a good time to check for updates for your router to ensure that your network is secure. You may also want to test your wireless security settings, as well as change your passwords to sensitive data.
If you keep up with your backups and system maintenance, you should feel confident that your data will be secure for another year. In the event that your data has been lost, contact Recovery Force customer care at 866-750-3169 for information on how our team can assist you in the retrieval of your data.
Powered By: Crafty Syntax
Tell others about
Recovery Force.
Bookmark and Share
Follow RecoveryForce on Twitter
Customer Comments
David Lai
Visions By David
Mississauga, Ontario
"Being a first time victim of a hard drive failure, I was understandably scared and nervous about the success rate of using a recovery service.
Needless to say, thanks to you, my fears are unfounded.  Not only were you able to recover all my photo files but the step by step updates kept me at peace.
The service is not cheap but it's a whole alot cheaper than losing my client images!
I would like to thank Luke and the Recovery Force team for saving the day for me!  May the force be with you!"
